I'm new to this level of woodburning so please bear with me...I need all the help I can get. I recently moved to a house that has a cheap-open factory fireplace & would like to replace it with a high-efficiency zero-clearance woodburner. I'm researching the options available & ran across the Lennox Montecito.
It looks like Lennox has been buying market share in the 'hearth' industry for the last few years. From what little info I have run across on Lennox woodburners, people's opinions have ranged from "look elsewhere" to middle of the road to pretty good. Naturally this view must largely be a function of the companies they purchased as it doesn't appear Lennox has had much time to make their mark(good or bad). (Again bear with me, as I've only been able to locate bits & pieces of info).
The Montecito(small one, not the "Estate") looks to be a re-branding of the Bis Ultima(Lennox owns Security Fireplace). All the specs match up as well as the wording in the specs themselves. With the Montecito being part of launching the new(?) "Dave Lennox Signature Collection" I would guess the Bis Ultima unit had a new face put on it & got the name "Montecito". Taking existing products, particularly from a company that was purchased, and re-branding them into a "new" product is standard practice & inexpensive to do as compared to designing a new product from scratch. From what I've been able to gather, the Bis Ultima is a pretty well thought-of unit.
Is anyone running a Montecito or know anything about them? Any key items(construction, options, warranty...) that I need to investigate? ....For that matter, what makes a good stove or HE fireplace good and what corners are cut that makes a unit something to avoid? I've been researching on how to buy a good unit, but I'm finding little in terms of stove-construction specifics...other than "buy a good stove".
I'm pretty partial to the Jotul Kennebec...but this isn't zero-clearance..any other options worth checking out?
thanks..
(broken link removed)
http://www.securitychimneys.com/pages/fireplace/high_BisUltima.asp?country=ca
thanks..
