hi and low temp switch reversal
zrock
1,602
bc
Just checking to see if its possible if the POF switch was switched with a high temp switch on a breckwell if it would run properly? I just changed out the POF switch and pretty sure that someone previous had put the high temp in its place. The extra screw hole under the switch and the original holes held the new switch perfect and looking at the switch with oem version they are one in the same
Well to answer the question yes u can reverse them and it will work... just takes much longer for the blower to come on... with the new switch the blower kicked on in about 30 seconds of a full flame. Where before it would almost take up to 3 min or more...
Sent from my SM-G950W using Tapatalk
