Mine is a true multifuel and I have typically burned only corn in it till a couple months ago when my pellet grinder arm busted. I went ahead and ran it without the auger which they said couldn't be done. It worked and pretty well at about half the noise. Since I had a couple bags of pellets of pellets I decided to mix em and came up with a formula by which the pellets burn some way enough to keep the corn from turning into a clinker. The ratio is 5 to 1 corn to pellets. Use that mix and the stove runs at least as well as it did before and is a lot easier to maintain. The key benefit is so much less noise. Cleaning the back of the beast where the junk tends to settle is a snap since the only headache is removing the cursed auger. Now it just pops apart. No more volcanic fallout all over the deck anymore either, it stays in the tray or the clinker. The only down side is yanking out the clinker once a day which isn't any more messing around in there than there was before so it all works out the same to me. I never was much on the leave it run for 3 days on low thing anyways as it always seemed to shut down sometime anyways from the stirrer breaking up the fire too much sometime or other.
Anyways, thats about the mix to burn corn in a pellet stove if some of you are finding pellets to be too expensive or unavailable. If I lived in the Midwest I wouldn't even have a pellet only stove but I see some folks do. Run that ratio or something close to it and a pellet burner should burn corn pretty darned well, its just dirtier and needs cleaning more often. The trade off is that it requires cleaning more often but is lots cheaper to operate. The only difference in heat output is that its hotter so that with mine you just don't run it on Max heat burning corn. Not rocket science at all. My stove is somehow magically rated by the manufacturer to run good old "P VENT to burn corn. In three years all I see is some staining on the inner liner, nothing more burning 4-6 tons a year. I will get around to welding the auger sometime or mabe even buying a new one but not anytime soon.
