Hello,
Looking for some advice for re-installing my wood stove. We are semi-finishing the basement and are putting a wall up between the existing masonry chimney and the stove. This is to section off the area where the oil-burning hot water heater and my work benches are from the rest of the basement (planned den/recreation area). The chimney is located at roughly the center of the basement. I built the section of wall between the stove and chimney out of cement board since it is not combustible, and spaced out the studs so there are no combustibles near where the pipe needs to go through the wall.
My stove uses 6" pipe and my chimney has a 7" opening. Prior to building the wall, I have been using normal 6" stove pipe and a 6" to 7" adapter to connect the two. This worked great, and with my almost 30 foot chimney I have always had great draft and no smoke leaking out of the connections. We have a small stove that is only used for supplemental heat in the basement and only runs a handful of days a month - though I expect this to change once the basement is more fleshed out.
My issue is that I am unsure of the best/safest way to route the stove pipe through the wall. I have a 6" Selkirk 206463 wall thimble that I had intended to use, however the opening in the thimble is made for a larger pipe. I believe double-wall chimney pipe, based on measurements I have found online. The instructions that come with the thimble are useless.
As I see it, my options are:
1. Cut a ~6" hole in the cement board, tile around it, send the stove pipe through with a trim collar, connect and call it a day.
2. Install the thimble and use a short section of chimney pipe along with a handful of adapters to go from stove pipe to chimney pipe back to stove pipe to chimney.
3. Install the thimble and send the stove pipe through, potentially with some kind of fireproof insulation around it to fill the gap.
#1 would be easiest but I am definitely concerned about the safety of it. Cement board is non-combustible but I'm still not sure it is safe to have it right up against a hot single-wall stove pipe. Maybe use 6" double-wall for this?
#2 seems like the "right" way to do it, though I don't know if the adapter I need to go from chimney back to stove pipe even exists, or if there is another fitting that is supposed to be used to go from steel chimney pipe to a 7" masonry opening.
#3 gives a nice compromise between the two but would be the least visually appealing. I suppose I could use a trim collar to cover the gap, but I'm still not sure this is the best way to do it.
Any thoughts?
Any thoughts?
