Hi, I am new to this forum and new to a wood burning insert. I just recently started looking to put a wood burning insert in our home because we recently had a fire in our fireplace and apparently the fireplace was not built properly and the mortar cracked and it ended up burning through the floor and burnt the floor joist and filled the house with smoke. LUCKILY we were home when this happened and the fire dept. got it taken care of quickly.
So, now that the fireplace has to be rebuilt, we would like to redo it with a wood burning insert. The fireplace will be rebuilt to code this time but we would prefer the efficiency of a wood burning insert. I am very confused on what size we should get. We are not looking to heat the whole house full time with it, just provide a cozy area in our family room and maybe the heat will spread to the kitchen and play room with are adjacent to the family room where the fireplace is located. I would like if it reduces the time our furnace runs some, as well. The fireplace is located on the right side of our home. The home itself is 4400 sq ft, but this floor is about 2400 sq ft. The room where the fire place is located is about 25x15 with cathedral ceilings. I am worried that I am going to pick something that will be too hot for us in the one room and we won't use it because of that.
I would appreciate any advice and suggestions. Thank you in advance
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
