In some need of suggestions on how to fix my vent setup.
Replaced a PDVC with a PS50 this fall in a corner install. The PDVC was vented as following - Appliance adapter - 45 Elbow - 2' Horizontal Section - Cleanout Tee - 5' Vertical - 90 Elbow - Termination Cap.
I know this is above the EVL for a 3" pipe, but the setup actually performed pretty well, no airflow issues. In order to install the PS50 without it being into the room I had to add another 90 Elbow after the appliance adapter in order to get the pipes to line up. So now there is a 90 and a 45 elbow one after another before I get to the 2' Horizontal.
The stove actually runs pretty well with this setup, but the glass gets dirty very quickly - even after a complete cleaning and leaf blower. I am debating on whether I should just go to a straight out vent or replace the complete vent and go with 4" pipe. Picture is attached just in case there was another option that I am missing. I do not want to move the location of the thimble.
Option #1 Straight Out - Appliance Adapter - 90 Elbow - 45 Elbow - 2' Horizontal - Termination Cap. The termination cap would be 70" above my lawn. If I am understanding the requirements correctly this is acceptable. This method would by much cheaper, I would only need to buy a battery backup in case of power failure.
Option #2 Change to 4" Pipe - Appliance Adapter - 90 Elbow - 45 Elbow - 2' Horizontal - Cleanout Tee - 5' Vertical - 90 Elbow - Termination Cap. This option seems to be very expensive $600+
Thanks in advance for any suggestions!
[/URL]
[/URL][/IMG]
![Help With Venting Help With Venting](https://www.hearth.com/talk/data/attachments/172/172166-7f1134f2f1c1af629775e0e2739ebaed.jpg)
![Help With Venting Help With Venting](/talk/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fs1106.photobucket.com%2Fuser%2Fpaintbalfruit98%2Fmedia%2FIMG_20160116_134555761_zpsvyhvgaiz.jpg.html%5D%5BIMG%5Dhttp%3A%2F%2Fi1106.photobucket.com%2Falbums%2Fh363%2Fpaintbalfruit98%2FIMG_20160116_134555761_zpsvyhvgaiz.jpg&hash=5f6a54ea0d6c56bbbc35d260349c6ecc)
