Help! I'm trying to install the connector pipe by myself and the offset is becoming the bane of my existence. I telescoped the pipe from the stove up to the same elevation as the chimney connector, plumbed it and the offset is 20". According to the DSP offset chart, I need 12-18 adjustable length. It has a 45 on each end. It will not extend enough to reach from the telescoping length to the chimney connector. I have conceded that I will need another 6" length but I don't know why unless the chart is wrong.
And the DSP is not fitting well over the chimney connector. Looks like it will need a good bit of persuasion in order to get it on enough for the finishing band to cover. Once I get it on there I will not be able to rotate the elbow so it will need to be in alignment when i drive it home.
I'm sure there's something about this i don't know. Hoping someone can clue me in. It's a pain in my sore back.
