In my last thread I feel alot of things got lost in the discussion. I'm starting a new thread with my newest drawing. I would like everyone to please review and post any comments or suggestions.
I'll post again my plans for this system starting at the boiler.
Keep in mind all pumps are grundfos 15-58 circs. except for the storage to house pump.
The boiler pump will run from the boiler shed into the garage to the plate HX then back to the boiler. My heat dump system will be tied into this loop. If the return line to the boiler gets too hot my heat dump will pull off the boiler supply line to a water to air HX that will have a blower on it to cool things down. In a power outage my boiler has a damper that will shut so an out of control situation can't happen. My boiler protection valve will also be on the boiler to storage loop.
Now from the plate HX
My storage tanks will have a pump on the return line after the manifold connections to push water up through my plate HX to get my counter flow. I'll be running reverse return with step down manifold plumbing on my 3 tanks. I will have my garage heating loop pulling from the supply manifold up through my water to air HX in the garage. The pump for my garage loop will only run with a call for heat.
My storage to house pump will be a setpoint T pump and it will be in the house crawlspace pushing into my house manifold. From my house manifold I'll be pumping out to my HX in my furnace. The "storage to house" pump and HX pump in the house will only run with a call for heat. I have a 90 feet long underground run to the house manifold and it was suggested to run a setpoint pump for that run which is why i drew it that way.
A question I have about running to my house is, my plumbing has to run about 15 feet across my exterior wall in the garage before going into the underground line. Could I run this line in the wall through the 2 X 4 studs and then use closed cell foam around the pipe? Would that be enough insulation to prevent freezing? Or would there be a better way to hide this run?
Here's the new drawing
![Help with storage plumbing 2.0 Help with storage plumbing 2.0](https://www.hearth.com/talk/data/attachments/177/177473-ab09ac763119e67a737e4fa97e23bb15.jpg)
