Hello, got a Quadrafire Mt. Vernon pellet stove. Earlier this heating season the blower fan started squealing and would not start up when the stove was hot enough. I usually run the stove on the medium setting, which works the best for the area that we have it in. When the blower started to act up, it would not blow on the medium setting but if I turned the heat setting to high, it would start up and then I could turn the heat setting down to medium and the blower would stay running. I have since replaced the blower with a new one from Quadrafire and it worked ok for awhile but now it is doing the same thing. If I set it on the high setting, it burns too hot for the room we have it in and it will cycle on and off too much as well as use too much pellets. What is wrong with my stove and where should I look at to get it fixed? I have done all of my own service work on it, and so far it has run flawlessly for 6 heating seasons 24/7, and this is the first problem that has stumped me. Thank you for any help.
