Hello
I'm new to posting on this forum, however have been reading and learning from everyone who so generously have been giving such good information on their various experiences. Thank you!
I used to heat exclusively with wood in my 1500 sq. ft. ranch style one-story home in northern CA with a 1970 version Warm Morning stove. It was a wonderful stove that could cook me out at times with a yummy fan that actually blew from the bottom of the stove to keep our toes nice and toasty! I miss that stove! It finally burned out after 23 years and I made the choice to go to a free-standing gas "wood-looking" Waterford stove in its place so I could have "push button" heat. It doesn't heat my home as well as wood and I've always wanted to go back to wood someday, but not exclusively. (Which means I now need to buy two heaters for my home...wood and a propane type heater.)
Well, someday is here and I never thought buying a wood stove would be so difficult a choice! I have been trying to choose since the beginning of September and it's now almost December and, although I know so much more about wood stoves (probably even more than I want to), I still cannot come to a concrete decision and it's getting colder!
Here's my situation.
Mulebelle
- Northern CA mild temperature (relative) getting to +20 sometimes and very wet during the winter months (read...feels cold!).
- Three bedrooms at one end of the house, hallway and living room, kitchen, dining area at the other. 1970's insulation, older double pane windows that are metal, and I would not consider them air tight because when windy, the temp inside the house drops rapidly. Live on a hill in a canyon so winds are fierce and come from every direction.
- There are 12' cathedral ceilings in the living room (where the stove will be) as well as a back bedroom (at the other end of the rectangular house). There are ceiling fans in all bedrooms and in the living room.
- I have a corner install that really requires a right-hand door opening. Most of the stoves have left-hand door openings. I am concerned about heat, flame, smoke escaping when loading from a top load but have no experience with top loads. (Although loading without bending so much does appeal to me!) Any info from experienced users would be helpful. I am leaning toward having a front-load option because I am thinking it would be easier to load larger splits and position them well to get a good overnight burn. I really like a large right hand side door load (maybe because that's all I have ever had, but it's easy to sit on the hearth and fill the stove that way in my set-up). I think the Keystone's door is way too small.
- My hearth is made from 4" x 2 1/2" brick with a 1" airspace between it and the sheet rock wall and the floor of the hearth sits directly on the plywood sub-floor that has been reinforced with extra floor joists. I'm a little concerned, after reading some of these posts, that my hearth may not be good enough for the clearances that are needed with the new EPA stoves.
- I have single wall stovepipe (with double wall going through roof area), but this will all have to be changed as it is set-up for the gas fireplace so I have options there.
- I have 2 cords of Oak from a tree that fell & we cut & split in fall of 2011 and it was stacked early spring 2012 to dry in the sun and wind. I also have 2 more cords of "dry" Oak that I purchased from a very reliable local firewood dealer here that I have done business with for several years. Everything is cut to 16" length, but there are some longer pieces.
- Long enough burn time that I can just stoke the fireplace with logs after about 10 hours or so. This way in the A.M. I don't have to restart the fire. I don't mind adding a log now and then during the day but would prefer I could be gone most of the day without having to re-start the fire.
- I would like to be able to cook on the stove. (A little concerned with the winter grill on the Rangeley getting food splatter inside the stove area.)
- Easy wood loading as I am getting older, not younger. Preferably a right handed door (large) and also a front load for wood maneuverability.
- Even heat would be nicer than very hot for a few hours then quite a bit cooler until reload time. I understand that the soapstone stoves and/or catalytic stoves would be better here.
- I like the ash pan from the Progress Hybrid...it looks as long as the stove is wide and that's what I had with the Warm Morning that was awesome!
- I really don't want to have to clean the glass all the time to have the stove not look dirty.
- Looks: I don't really like the gothic look of the Fireview. The Progress Hybrid is nice, so are the Jotuls but the Rangeley is...well...acceptable I guess. The Qudrafire Yosemite is nice looking, right hand doors but I'm concerned it isn't large enough a firebox for good overnight burns or a big enough stove for my home, and I'm not sure I could cook on it.
- Great reliability and customer support. (I think that Woodstock has this nailed from what I read.)
- Jotul F50 Rangeley
- Jotul F600 Firelight (If this had a single door [with a right-handed handle] it probably would be on top of the list.)
- Quadrafire Yosemite (maybe too small for my house?)
- Quadrafire Cumberland Gap (local dealer said hinges on right hand door break easily)
- Progress Hybrid (No front load option and takes a longer time to get a build and delivery & then have to find someone to install)
- Hearthstone Manchester (I think the ramp-style side door with be cumbersome and potentially a surface to burn myself on)
- Lennox Grandview (concerned with fact the line has recently been sold by Lennox from what I read.
- Other suggestions?
Mulebelle
