Hello,
I'm looking for some help and opinions. We just purchased our home and want to replace the Superior HCE-4050A model wood fireplace (Installed around 1994). In looking at doing so, I've been researching a bunch of different models and we really like Quadrafire 7100.
Our current FP is on an exterior wall, 1st floor with an exterior chase box approx 51" wide by 26" deep. According to the specs I have two options for running the outside air inlet...depending on which option we choose the rough opening measurements change. Seeing how I really don't want to redo the chase and make it wider I wanted to stick with the approx 43" width RO option, and run the air inlet directly out the right side of the FP...the fireplace company doesn't want to install it that way, and wants to run the air inlet out the back of the FP, making the RO 50 7/8" width. With framing etc I can't do the wider option without changing the chase dimensions. (I haven't looked inside the chase yet to see what was used to frame it, but I have to imagine it was done with 2*4's.
Salesman discussed air directly coming into the air inlet and if there isn't a bend in the ducting it will consistently allow cold air into the home. I thought this model has/had an Outside Air Control Handle to close the air inlet when not in use. He mentioned frost building up in the winter because of this.
Our current air inlet faces to the East, and if we moved it with the 7100 to the right it would face to the South. We also have a four seasons room that faces to the south that would help block the wind.
We are new to wood burning, so thank you for the help.
![Help with new install-Quadrafire 7100 replacing old Superior Help with new install-Quadrafire 7100 replacing old Superior](https://www.hearth.com/talk/data/attachments/154/154650-6962c66036d7e8bc50bde337a39c27f7.jpg)
