I am new to this site and new to outdoor wood boilers as well. We recently moved to Minnesota and the house that we bought came with an outdoor wood boiler for supplemental heat.
Here is some info about my system. The boiler is a Heatmor model 200. It appears to be an older unit. short story, the guy we bought the house from runs his own business. He received the boiler as partial payment for a job that he did. He told me that he didn't use it much because electricity is cheap (ok.........) and he was never home enough to keep it stoked up. Our house runs off geothermal forced air, but there is also a plenum inside the ductwork that has lines running out to the boiler. We also have a 38x50 shop with floor heat. That has an electric boiler, but i can close a few valves and open others to run it off the outdoor boiler as well.
Being new to the whole boiler game, I have some questions. First and foremost, how do i know how much coolant is in the system? I can not find a gauge of any kind on the front of the stove, so i don't know how much coolant is in there. I have added about 20 gallons of RV antifreeze to the top of the stove. Right, wrong or indifferent, that's what I used. My biggest concern is that I may end up running the system too low on coolant and wreck something.
Should I have a certain amount of pressure in the lines?
How can I check to make sure that nothing is leaking?
I really don't like the way that everything runs into the shop. The closed loop in the shop works great with the electric boiler. I keep about 5-15 psi in the lines and don't have any issues. Although, that electric boiler only gets to about 120 degrees. Not sure if it should be higher or not. When i choose to run the wood boiler in the shop, i have to shut the 2 valves that loop through the electric boiler. i then open the 2 valves that loop outside to the wood boiler.
I only burn wood when it gets really cold (10 degrees and lower). This is primarily because we moved into the place the end of October and i never got a chance to stock up on wood. My electric boiler runs on offpeak from 11p to 7a every day. so in the evenings, i end up going out and reversing the process to get back on electric. The problem is, when i switch to wood, i lose all of the pressure in my lines. when i loop back to electric, i have to take a pump and add some coolant (usually less than 1 gallon) to get pressure back in the lines. what i would like to do at some point is set it up so that i can burn wood and run the shop off that, then if the wood burns out or we aren't around to stoke it, it automatically switches over to electric.
does anyone have any advice for a newbie that wants to save some coin by burning wood? I have attached some pics of my stove. as you can see, it's not in the greatest of shape. is there a place where i can download an owners manual for this thing for replacement parts?
![Help with my Heatmor Help with my Heatmor](https://www.hearth.com/talk/data/attachments/154/154246-0ef9322f1a3197348f056adff19f5379.jpg)
![Help with my Heatmor Help with my Heatmor](https://www.hearth.com/talk/data/attachments/154/154234-0c14cc0cd88d407b711cdc622203ef7f.jpg)
![Help with my Heatmor Help with my Heatmor](https://www.hearth.com/talk/data/attachments/154/154235-9ddfb4ba3b1d08b800c4777bfcefd3d3.jpg)
![Help with my Heatmor Help with my Heatmor](https://www.hearth.com/talk/data/attachments/154/154236-3d5917d98d3664d7b3b7f5f0962b4be5.jpg)
![Help with my Heatmor Help with my Heatmor](https://www.hearth.com/talk/data/attachments/154/154237-f96620c0ddecb52b91143bd9ff538e02.jpg)
![Help with my Heatmor Help with my Heatmor](https://www.hearth.com/talk/data/attachments/154/154244-0d7168a0c56572abb2bd53eff0cdfcf8.jpg)
![Help with my Heatmor Help with my Heatmor](https://www.hearth.com/talk/data/attachments/154/154245-46808a902e398267f95503371cfd04de.jpg)
