Hi everyone,
I recently bought a 1983 built house with an old wood burning stove which is likely original to the house. The identifying plate on the back left of the stove says the Model is Mountain Aire 15 RM however I can’t find any information on this stove at all. The only thing I’ve found so far is another post on this forum from 2012 where another person has a similar issue as me, but there was no resolution posted and the thread seems closed. (https://www.hearth.com/talk/threads/identify-and-troubleshoot-old-stove.99694/)
![Help With Mountain Aire 15 RM Help With Mountain Aire 15 RM](https://www.hearth.com/talk/data/attachments/321/321283-c8e4d9c38d8ae072bd689a807e06f344.jpg)
I’ve never owned a house before or a wood burning stove. The previous owner gave me a quick run down on how he used it and one thing he mentioned is that he always had to leave the door cracked slightly to keep the fire going. I’ve used the stove a few times now. It seems like the only air going into the stove is through the door which if closed will smother any fire inside. However, the back plate specifically says “Operate only with the door closed.” There is a pipe below the stove and some sort of opening at the back of the inside of the stove. There is also a rotating lever/handle on the back right side of the stove which has the letters “H” and “L” on it. Rotating this handle moves a vertical rod slightly up and down. This vertical rod connects to a horizontal rod that goes into the back of the stove into an abyss that I cannot see inside. The opening at the back of the stove seems to be clear of any debris. That’s about all the info I have.
![Help With Mountain Aire 15 RM Help With Mountain Aire 15 RM](https://www.hearth.com/talk/data/attachments/321/321286-c2134b4ff2212a02505d869d3da72d1d.jpg)
Does anyone know more about how to operate this stove? Can anyone help me try to figure out why it is only drawing air through the door?
![Help With Mountain Aire 15 RM Help With Mountain Aire 15 RM](https://www.hearth.com/talk/data/attachments/321/321289-89c84b0845960b7bcebf9bd3cd16d136.jpg)
![Help With Mountain Aire 15 RM Help With Mountain Aire 15 RM](https://www.hearth.com/talk/data/attachments/321/321282-41491a2ef42e5c5783c3d0a5f50ebd4f.jpg)
![Help With Mountain Aire 15 RM Help With Mountain Aire 15 RM](https://www.hearth.com/talk/data/attachments/321/321284-f4f4bacf2f762bb82daa89be0b301848.jpg)
![Help With Mountain Aire 15 RM Help With Mountain Aire 15 RM](https://www.hearth.com/talk/data/attachments/321/321285-58c14b5541cdb8c0066637408eb5f5ab.jpg)
![Help With Mountain Aire 15 RM Help With Mountain Aire 15 RM](https://www.hearth.com/talk/data/attachments/321/321287-5d6f74296f351bf78bd4ddbb23d63390.jpg)
![Help With Mountain Aire 15 RM Help With Mountain Aire 15 RM](https://www.hearth.com/talk/data/attachments/321/321288-97e0a5e9afaf92be9c2b62aecc116995.jpg)
