I am new to OWBs but just bought one for a good deal to heat my large shop and would like to connect to my house as supplement heat
the boiler location will be approximately 75 feet from the barn BUT i want to enter the barn/shop heat the shop with hanging hydronic heaters that I already have and then exit the shop and go to my house ANOTHER 85 feet. I will then pump through a few baseboard heaters that I already have tie into my DHW for to cut the electricity out of my wife's shower taking and then loop back the same distance back to the boiler.
75 feet to the enter the shop -- under ground insulated pipe
90 feet to cross the shop to exit to the -- this will run along the walls and I can build furring to help insulate but it will be in a heated shop
85 feet to the house --- again insulated underground pipe
I estimate that to be approx 280 feet one way when you calculate bury depth and going up the walls to get around large garage doors
The boiler is rated for 225K but know the efficiency is not there. Figuring 20 delta T.
KEEP IN MIND that the shop will be the primary load I just want to use the boiler to help me get through the night with some baseboard heat to break the chill as the indoor fire begins to die out and to help break the chill on days that I really do not need a fire. strictly supplemental to avoid burning oil as little as possible
Barn/Shop -- 50x50 40R walls and 60R ceilings
Home 1400 feet log home-- LARGE larges and very tight with 3x pane windows
Estimated heat for shop alone is 180K range but this is if you keep it 70 year around I am ok with it being in the 50's as I have another wood burning stack to help supplement while I am in there.
Recommendations was to put 1 1/4 to barn and through the barn to exit point to house then drop to 1 inch to house. I would like to do a good install but want to save where I can. Running a separate line to the house would be very costly as the loction of the boiler would add lots of feet to underground pipe. Please help as winter here in Alaska is right up on me and I have limited time to do this before the snow flies.
Question are this ---
Size of pipe
Size of pump
Is that distance to far for 1 1/4
Size of pipe
Size of pump
