Help with a hearth.
21
Middle Tennessee
I am going to be building a hearth for my Oslo to sit on, and I want to over engineer thinking ahead to the future (in case I get a different stove that needs a higher R value).
The installation is on the first floor with wood floor joists and 3/4 decking.
I am planning the layers as such:
1. Micore
2. steel
3. Durock 1/2"
4. thinset
5. tile
I found these panels that someone linked to @ tractor supply:
[Hearth.com] Help with a hearth.
They are micore with steel over them and an R value of 1.5.
I would like to use them instead of 2 seperate layers (micore then sheet metal).
My question is, will it matter if the seam for this is under the stove? My hearth is going to be 72"wide X 60", so I will also have a durock seam under the stove.
Should I seal the seams with something? If so, what?
Also, can I use the cut off from this panel to fashion a blockoff plate (existing masonry chimney), or would the micore not be good that close to the flue?
Thanks in advance.
If you can get micore locally I think you can skip the metal layer. But your plan of using the premade pads for underlayment might work. Maybe flip them over so the Durock is applied to the smooth backside. Screw down every 8".
