I could use some advice from the owners and users of pellet stove inserts. I'm not new to wood burning as I have burned wood in fireplaces, good wood stoves and wood stove inserts. I'm debating between two wood pellet inserts , One is a Harman Accentra and the other is a Quadra-Fire Classic Bay 1200. Both dealers are close by (within 20 miles). Looked at and saw both burn into a fireplace setting, one has top feed pellets the other bottom. The reason I'm leaning towards the Accentra is because it's cast iron, BTU's are about the same as the Quad, but I think the clean up on the Accentra is the easiest. The rail slide out system in the Harman seems the ticket as you do not have to break venting system in fireplace system to clean and I do like cast better then sheet steel. Please tell me your choice.
Rick
Rick
