Howdy--been reading this excellent forum for months and just registered seeking some advice. My wife and I bought a 1972, 1570 sq/ft contemporary house in April, and it has a Nashua N18 wood stove in the basement. We believe it was original from when the house was built--and had it inspected and cleaned prior to use. I have 2 cords of wood that seasoned for 2 years, purchased from a local woodsman in his late 70's who has been supplying firewood to those lucky enough to be on his list since he got back from Vietnam. I got onto his list because my Mother has been buying her wood from him since the late 70's. He loads and inspects each piece by hand, and my friends who helped stack it said it was the best wood they had seen. It is a mix of red oak, ash, birch, and maple.
The problem I am having is getting good heat from the stove, and I have tried to follow all the advice I have read here. I start a fire with the front vents wide open, get it up to about 350 on the flue gauge, then choke them down to about 1 turn open. 30 minutes later the temp will have dropped to 220-250ish, so I open them wide again and it gets going, but it is just eating wood. The house never gets very warm (mid to high 60's in the rooms right above it) and if I choke it down for longer burns the temp just goes right back down. It also has a butterfly switch in the flue, which I leave open while burning. It has a blower and vents tied into 1 duct going into the living room, and one going to a finished room in the basement, under the bedrooms. Running the blower or not doesn't seem to make that much difference in heat distribution. In the pic below of my current burn, I have had it wide open for about 30 minutes trying to get the temp back up. When I look at the chimney I do not see smoke, so I think that means I am getting clean burns, but given what I have read about people with similar style stoves overheating the house, and given how much wood I am going through (this thing literally just devours wood), I do not think the current amount I have will last through January--the coldest time of year. The house is all electric baseboard, which I am trying not to turn on and when we first moved in and had to use them lightly I nearly fainted as the first bill.
I grew up in a house with a 1978 Vermont Castings Defiant in the living room, and I could get that thing cranking to the point where we had to open windows. It would burn all night and the house would be a 75 degrees. I feel like I must be doing something wrong with this Nashua, as other people rave about these stoves. I do a final load at midnight, get it roaring, then choke it down and by morning (7am) the stove is barely warm to the touch and there are almost no coals left. Any advice is greatly appreciated!
![Help using 1972 Nashua N18 - not getting the heat I expect Help using 1972 Nashua N18 - not getting the heat I expect](https://www.hearth.com/talk/data/attachments/286/286728-f4a9d55870c55d68fae2a21e3b9b9b57.jpg)
![Help using 1972 Nashua N18 - not getting the heat I expect Help using 1972 Nashua N18 - not getting the heat I expect](https://www.hearth.com/talk/data/attachments/286/286725-4efd62a34037cafb805d213196a56116.jpg)
![Help using 1972 Nashua N18 - not getting the heat I expect Help using 1972 Nashua N18 - not getting the heat I expect](https://www.hearth.com/talk/data/attachments/286/286726-7da396ea164bb460d33b385cf739b5c6.jpg)
![Help using 1972 Nashua N18 - not getting the heat I expect Help using 1972 Nashua N18 - not getting the heat I expect](https://www.hearth.com/talk/data/attachments/286/286727-fe77513d249700629948818bc7c4f78d.jpg)
