We have tried everything but do have a unique set up![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Our Country Striker S / SA 160 is not getting hot/heating the living space it should at all (700-1400sf). We cannot get a fire to the recommended burn range - even if it looks like it's raging. Our facts/efforts/set up are below. (I did search these forums with no new leads and did try to provide all the info asked for as noted in other questions below). Questions welcome - I will also add a few noteworthy items:
I searched high and low for this specific look and the reviews on this wood stove are very high! All input is welcome!
Noteworthy:
1) What is the specific make, model, & year of your stove? Country Striker S-160
2) How long have you had the stove? Used - One Year in Use (dated on back Feb 11, 1997)
3) How old is your house & how well insulated is it? Full Remodel - Open Cell Spray Foam EXCELLENT Insulated.
4) Where is your stove located in your house [diagram if possible]? Centrally located on first level (about 1100 sf each floor/three floors). We want it to heat level 1 with residual going up stairs.
5) Moisture content on your wood & what kind of wood are you burning? Various, good mix and very well seasoned.
6) How high is your chimney? 3' Double wall + 24' Triple.
7) What are your outside temps right now? 30 Degrees
8) Does your stove have an OAK [outside air kit]? No
Random Questions:
Do the baffles go bad?
With this tall of a chimney (and I can hear and see the flame affected by wind) do we need something special?
PICS of SET UP:
![Help Us Solve Our Country Striker 160 Mystery! Help Us Solve Our Country Striker 160 Mystery!](https://www.hearth.com/talk/data/attachments/170/170326-48a9572d8b56ea22f080827fcaba5af1.jpg)
Noteworthy:
- This is our 2nd home with a wood burner. We are not pro's but experienced. I grew up loading the stove at home and the cabin and friends owned a wood stove store! I know the heat and feel of homes with wood stoves! We do have a unique set up (below) but something must be wrong.
- We had a Pacific Energy "Fusion" stove in the first home. It was higher efficiency and intended for a bigger space but with MUCH taller ceilings (twice standard /cathedral) and despite we had excellent heat in main living/open areas from wood stove burning. It was not centrally located (a last minute idea). Our blower was the first item to go so we used a commercial floor fan and ceiling fans to push heat and it worked excellent! The house was big and open and it roasted.
- We Use WELL seasoned - split, dry, wood.
- The wood burns faster than it should despite any setting (not heating as it should as it burns fast
ARGH!).
- We did buy this Country Striker used (but so were both my dad's stoves). We have not been able to get this to perform even moderately or anywhere near the last one or any that I've lived around.
- We did put new fire brick, a door gasket and get a new fire blanket.
- We do have a three story home, 24' triple wall chimney (+ 3' of double wall from the stove).
- Last - I know this is a sore spot on the forums but we do not have a blower on it. As in the past, we do use floor fans to push the heat and keep our ceiling fans going to move the heat
Random Questions:
PICS of SET UP:
![Help Us Solve Our Country Striker 160 Mystery! Help Us Solve Our Country Striker 160 Mystery!](https://www.hearth.com/talk/data/attachments/170/170324-d178aa16a5030aa788bb5cae034ea667.jpg)
![Help Us Solve Our Country Striker 160 Mystery! Help Us Solve Our Country Striker 160 Mystery!](https://www.hearth.com/talk/data/attachments/170/170325-bfcff564bd45d96f58a294e13719f240.jpg)
