My splitter has been faithful and reliable for six years now and well maintained. I hadn't used it in about six weeks or so and went out last weekend to start on this coming winters stock. It started on the second pull as usual, with the choke closed. I typically give it several seconds and start easing the choke to midway where I'll leave it for a minute to warm up then open it fully and everything is fine. This time I start easing the choke towards midway and it gags and stalls out... :gulp: This is not normal... So I start it up and long story short, it will run with the choke fully closed as long as I want but will stall everytime I try to open it. I've completely changed the fuel in the tank (it's always had fuel preservative in it anyway), tried running Marvel Mystery Oil through it (usually cleans anything out), took the carb off and completely cleaned it out and checked everything. There was a chunk of rubber in the fuel line but it made on difference when I took it out. Took the muffler off, no difference, took the air filter out, no difference.
Any ideas?
What is it that engages the automatic throttle? Lever? centrifugal clutch? Vacuum?
I need my splitter
- It's the Honda OHC engine 5.5 HP.
Any ideas?
I need my splitter
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
