Hi, I have a tiny settler's cabin on my property that is about 300 sq. ft. It is two stories, with one room on each story, no water or bathroom and is currently heated by two small radiant heaters installed on the main level. They do just fine. The upstairs is accessed via a stairway in the corner and that is the only opening. The upstairs gets plenty of heat from the current radiant heaters. The cabin has lots of windows and a glass paned older door. It has a crawlspace that is well insulated and the roof and upstairs walls are insulated with blown in foam but the main level is just the logs and chining (logs are about 16-18 inches in diameter).
We want a wood stove for emergencies but it needs to be UL listed to be approved for homeowner's insurance. The stove would be on the main level against the west wall. Our local stove dealer has recommended the Jotul 100F, but he says the tile base needs to be 37x40", which is way too big for that cabin as it would stick out into the room too much. I can't seem to find any smaller stoves that are UL listed or that could exist with a smaller tile base. My wife thins we need to find a small masonry heater somewhere but I can't find anything this small.
Any recommendations?
