I was wondering the best way to replace if anyone has had to do. and if its safe to operate the stove while waiting on new one. Old one is still in just split from one end to the other..
natedawg3256 said:Finally recieved my baffle for my crapsbury almost took a month to get in. Hearthstone has horrible customer service. But any way had to remove the top of the stove to replace the baffle only two 10mm bolts wasn't to bad to replace.
the display model in my showroom has furnace cement holding the air tube plemun together, and gasketing between air riser and baffle assynatedawg3256 said:They covered it under warranty, so i can't quote u a price. no cement it has a gasket.
Jukeboxfun said:If that lid is on with a gasket I may buy a sooteater and clean from the top down without taking the pipe apart. After running that down I could take the lid off and vac it out.
But any way had to remove the top of the stove to replace the baffle only two 10mm bolts wasn’t to bad to replace.
Mike from Orono said:I just thought I might add my experince to the thread.
My baffle on my Hearthstone II became severely warped from excessive heat. I knew I had to take off the 3 panel soapstone top and as careful as I was, I did cause a small chip in the surface (dang it). Anyway, because my baffle was so out of shape, even though I removed the 2 screws (I had to drill them out) holding it up, I could not maneuver it off of the the two hangers on the back wall to get it out the door. I had only two options, to change the shape of the baffle to get it out, or take the cast top off completely. I removed the 8 screws and the temp coil setscrew, and the top lifted off easily, no gasket. I could then easily pull the baffle out of the top, replaced it, and am now toasty warm and sipping a G&T as I type this!
