I recently purchased my first home, a 1957 ranch that was lovingly cared for by one set of owners until they passed a few years back and I bought it. I am slowly fixing things that need fixing and will eventually start upgrading/renovating the original bathrooms, kitchen, etc.
One of my first projects was rebuilding the small stone wall that goes around the front patio you'll see in these pics. Now I'd like to fix the patio itself, along with the slate walkway that leads from the driveway to the patio. The slates are all in good shape, few nicked corners here and there, but the main problem is they have separated from the concrete underneath and most of the mortar between them has worn away. Here is the overall setup:
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178026-3fa406837457a6c7c5221fb0b16e6e05.jpg)
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178027-689881b224da5da51186db0a87a63b94.jpg)
Close up of the patio slates:
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178028-b6c1170c0b96668d3852ce2a1c776fbd.jpg)
Exposed edges of the patio... looks like maybe a block wall around the perimeter, concrete slab on top and then another layer of mortar they were originally set in?
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178029-6c9ebda74016491780d9a5403cdc02bf.jpg)
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178030-0737702e7655e24bf20fdb99b42c241a.jpg)
Under the slates:
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178031-bfc2fdbeac271c6ba4c49236b75b6807.jpg)
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178032-af2ba9d9e9849521950a1507a40c2f3d.jpg)
And finally a close up of the walkway. The end near the patio seems to bet set on a thin bed of concrete/mortar, but not so much near the driveway end.
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178033-0a85e5f7707a947b3e37d5444c1bfe8f.jpg)
The portion of the patio that abuts the house is protected from the elements by the roof overhang and is largely intact.
![Help Repairing / Redoing Slate Patio and Walkway Help Repairing / Redoing Slate Patio and Walkway](https://www.hearth.com/talk/data/attachments/178/178034-2fba540ada8667c204637f29ffe34386.jpg)
The material looks to be in good shape so I'd just assume re-use it, and I have enough driveway room I could relocate all the slates while I prep the concrete underneath. I really don't want to tear up the slab if I don't have to.
Not sure what kind of base is needed for the walkway... the are thin so setting them in sand seems wrong. In NJ so frost is an issue.
Any recommendations for how to go about fixing this?
Under the slates:
