Hi All,
Thanks in advance for offering your knowledge and experience in this forum. I've been reading quite a bit in the last week or so trying to educate myself. Here's my situation:
I am currently heating 4000+ sq. ft. of area. Our house is a log home built 7 years ago and it's pretty tight. We have an Polaris LP boiler rated at 100K btu heating an "open" radiant floor system with PEX coils stapled to the bottom of the subfloor. We heat the garage slab and basement slab. Our last 2 months of LP use totaled $1250! I have to do something to reduce that. We've turned the thermostats down, but now it's just cold. I grew up cutting and burning wood and I've got an ample supply and equipment to do it again. I don't want a wood boiler in house. I don't want the mess, and I don't have the space for it and a storage system. That being said, I'm very seriously considering the CB E-Classic. I've also looked at the Greenwood Aspen 175 but I can't find many real world reports about it. I live 15 minutes away from the Sequoyah factory and I'm considering that option. I'll probably be doing a self-install. My plan is to locate the boiler about 30' away from the home and maximize the supply, return and HX sizes. I have a couple of specific questions. Our existing LP boiler heats both the radiant system water and the DHW. The boiler has 2 inlets and 2 outlets, however they are all connected together. I'm not sure about how to configure the HX. I assume that it would be best to use a large (50 or 70 plate) HX. Do I need to use 2 of them (one for DHW and one for heating)? It would seem as though 2 HX's would be more efficient. I'm not too sure about the tempering valve utilization or needs. Our LP boiler is set at 190* and sends that temp out to all zones. We have a mixing valve on the DHW supply to temper that down. I would assume that the HX would be piped before the LP boiler inlet(s) and "preheat" the water before it gets into the LP boiler. In that arrangement, the LP consumption would be significantly reduced. Am I correct here? Am I on the right track? I would love to hear about any of your firsthand experience with the boilers listed above or any other similar types. Any and all help is appreciated.
Thanks!
Chris
Thanks!
Chris
