hello all--
I've been reading all I can get my hands on (Sigenthaler's Modern Hydronic Heating, all sorts of MFG's publications, etc) and I get the basic drift of the variables of btus, delta T, flow rates, gpm, etc--
but-- I'm having a hard time pinning down an initial starting place to figure from
basically, what I am looking to to is not rocket science, but I am afflicted with newbie info overload
all I want is a primary/secondary system with the 150kbtu boiler feeding in by one secondary loop, a 1350 gallon storage tank feeding out/ in by another loop (with a plate HX and second set of circulators like NoFossil), and a finned coil in my furnace plenum to take the hot water, from whatever source, to the ducts to the house.
this'll all be in my cellar, in pretty close proximity, so no long, long pipe runs
I appreciate any tips of (a) what pipe and pump sizing have worked, or are expected to work, successfully, for the secondary and primary loops, pump sizing, etc.; or (b) a tutorial in where to start in figuring my way through all this in a way that I won't over-build anything, but also won't short anything on long-run efficiency
Thanks
Thanks
!! That is exactly what I was trying to get across. Sorry for the confusion there.......
