Hello everyone,
Sorry for the lengthy post but I wanted to provide helpful info. I've been lurking and reading and absorbing and want to come out of hiding now to get some advice from some experienced burners (I am newb at this). Early this spring 2021 we moved into our first home and I'm hoping to heat primarily or as much as possible with wood - it's been a dream of mine for awhile.
House stats:
All-brick rancher - 2400sqft total, 1300sqft main/ground level w/ 850sqft open area, 1100sqft mostly finished basement. I assume house is leaky. No insulation except attic on main level, and minimal wall insulation in basement. Layout attached. Orange and Blue are the heatpump HVAC supply and return main trunks, Green is where the existing stovepipe is located that isn't practical to use unless I did a basement re-model.
Starting from the top, our masonry chimney services both a wood-burning fireplace on main ground level, with an ash chute, down to the only unfinished portion of the basement (utility room) where an un-insulated and separate 6" stove pipe exists from previous mechanical needs, probably a furnace of some kind.
Masonry fireplace opening is 34.25Wx28.75Hx24.5"D
We have a 2-ton heat pump which our early-spring experience this year shows us that the dead of winter the heat pump won't be sufficient. The ductwork is shoddy, and leaky (and they just drywalled over it, which is super). I intend to fix the ductwork over the next several months and add dampers, re-balance, etc, which I hope will help my fight with physics having the stove on the main level.
Predicted stove use: The stove will be a necessity for heat when it's below 50deg F and we will be burning 24/7 DEC-FEB and maybe 50% of time in shoulder seasons. I'm thinking low, slow, and long burns are a priority over hot, fast and aesthetically pleasing burns, so I'm thinking catalytic, then hybrid in that order. It would be great to load a stove 1 time per 24hr period or longer. The longer between loads the better.
Other wants: Intending to install a stove ASAP into main level masonry fireplace and claim 26% tax credit for 2021. Unfortunately we don't have space for a fully outward freestanding stove on the main level and since the existing stove pipe in the basement is in the utility room, the basement really isn't an option for us - bummer cause now I have to fight physics. I'd prefer the stove to protrude from the fireplace opening so we can benefit from exposed stove area, or fit a freestanding inside.
Stoves on my mind:
--Blaze King Princess 32 - It won't fit in our masonry fireplace opening and we can't use it in the basement utility room. I wish,,,
--Buck 91 as an insert - seems once you get the cat going, it doesn't have to be so big and bad and you could load it up and run it on low at. Buck says it's low-end is 10,400 BTU and that "low" is the most efficient burn for it. I know the stove is capable of some serious heat, but it seems like low-and-slow with a hot cat is what this stove excels at and has a big firebox to load it up. I'm not sure why this stove can't get the runtimes the Blaze King can get with such a big firebox, or that's what I've gathered is the case. The 8" pipe requirement is a PITA and I have to knock out some terracotta according to my chimney contractor to get a stove liner to fit.
--Kuma Cascade Insert (or Alpine Insert) - flexibility of hybrid could be nice to do some occasional pretty burns
--Hearthstone Clydesdale Insert - hybrid plus burn time seems nice, open to soapstone but not sold on it exclusively, was reading about cracking,,,
--Hearthstone Castleton Freestanding inside fireplace - more soapstone on a hybrid and it just may fit inside our fireplace and perhaps the most aesthetic on this list to me since it's freestanding, but in this list tied with the Alpine for the smallest capacity
--Fireplace X Large Flush Hybrid-Fyre - caught my attention for performance
Anything appreciated, advice, other stoves to look at, corrections to my assumptions.
![Help Picking Stove - All-Brick Rancher Help Picking Stove - All-Brick Rancher](https://www.hearth.com/talk/data/attachments/281/281082-43c2c4210bce7b44c71b748c39dced1d.jpg)
House stats:
Stoves on my mind:
