Hi!
First post.
I'm in the process of purchasing a home,and the home comes with a gas fireplace.
Any way to figure out who made the insert?
No logs or anything present except the gas supply pipe coming into the insert.
There is no natural gas available,but the insert is installed in an outside wall.
It has some kind of venting system,as it has the 8" damper,has a cap/liner outside the home,which is surrounded in the usual vinyl siding.
Can someone explain the parts required to convert this insert to propane?
Most of the system is installed,I just want to complete the install in the most efficient manner to offset my heating bill.
This is a split level home,the fireplace is located on the lower level which is quite a few degrees colder than the main level.
I will get you guys some photos of the insert when I can.
Thanks.
First post.
Thanks.
