Our cabin in the Uintah Mtns of northen Utah is heated by a 1980's era Washington Stove Works wood/coal stove. It works fine the first two or three days, and then the cabin fills with smoke and there's no way to build any more fires. We've had the chimney cleaned, and it didn't help. It draws fine for the first few days, this only happens after it's been used for a while.
The pipe is about 18' high, including about 2' above the roof, but just barely over the peak of the roof. Coming out of the top of the stove is a 4' section of single wall pipe, then 2' of triple wall that goes thru the floor to the loft, then 5' of double wall, then 5' of triple wall to the interior ceiling. The altitude on the north slope of the cabin is about 8500'. Thanks a ton for your help.
