Help! Mystery pilot problem on greenhouse propane heater
Sjrily
2
Arkansas
Hi! Newbie in need of help/advice, so sorry about the length, but I didn't know what to cut. Some background: I've had a greenhouse for just over 20 years. For the first 10 or so I used propane. Propane became a hassle for various reasons, but mainly overheating the small space. I used electric until I upgraded to a larger, better insulated greenhouse last summer. In January I got a new propane heater (BTU output recommended based on surface area, insulation factor and area's low temps), new tank regulator, got my 100 and 40lb tanks filled up. I returned the first heater because pilot wouldn't stay lit (I did troubleshoot). I'd built in plenty of ventilation (our winters have become pretty brutal lately, with consecutive days, even weeks in single digit, sub-0 temps). Manufacturer wasn't helpful and only suggested it was too much BTU and I'd probably need to leave the doors opened. Didn't make a lot of sense to me, but I replaced it with a DynaGlo 12k BTU ventless propane wall heater (I purchased legs) and got that set up in February.
Same issue. As far as I could tell (I have smart temperature sensors and their app), heater would go through 3 or 4 cycles, then not come back on. I sat and watched what was happening, and always the pilot would just quietly snuff out when the burners were off. Never had a problem relighting.
So, I bought a second regulator, no go; tried various venting configurations, fans, I even used a fog machine to make sure there was plenty of airflow (even though DynaGlo manual states the room size for 12k would not be considered constricted); checked for leaks, obstructions, pilot positioning; googled for hours; called manufacturer (who was again no help since a licensed professional didn't install it). Finally returned that for same model.
Same issue. So now I'm thinking it's not the heater. Called a professional. Apparently pressure on the "preset" regulator was too high, so he adjusted it. Used 5-6 weeks till end of season, no problems! (I was SO happy).
Fast forward to last month. Fill tank, dust off heater, reconnect and check everything, fine for a week or so, then same issue, or I should say, same result (pilot out).
I videoed the normal pilot after burner cycle (attached); this was very similar to issue in February, where part of the flame at the tube would "disappear," then it would simply go out.
But instead of just snuffing out, it's like a high velocity something was acting on the pilot to the point where the flame "separated" from the pilot tube, and reappeared on the other side of the thermocouple (also attached); and there was a "high velocity" sound. I'm assuming the pilot goes out because the thermocouple isn't heated. It does this for approx 35-40 seconds before going out.
So, re-did most February's troubleshooting, (sans buying yet another tank regulator and using the fog machine), before calling professional. Different guy came out, admitted to not being too familiar with smaller setups. Said tank regulator had zero pressure. Opened the tank without the regulator to so me the tank had pressure. Tried the second new regulator, that had pressure. I saw analog gauge at 15, and assumed that was water columns (and it should be 11), I asked if he was going to adjust it. He said you can't, they're sealed. I told him in February they resolved by adjusting the other one, but didn't fight him on it, figuring with my luck, it's not unreasonable to have a regulator with barely a couple hundred to just go "bad" (even though we'd just had the heater on before testing pressure). He said to watch and if it happens again, call him and he'd come out again a bring another regulator.
It did happen again, later that afternoon. Three cycles, then 20 minutes or so later, pilot would blow off. Finding it hard to believe a regulator with a couple hundred hours on it and another new regulator with maybe one hour on it were both bad, I called to see if same professionals could look up my ticket from February, blah blah. Finally got ahold of someone three days later, explained everything again, and he said he felt bad, but he didn't know what to tell me. They don't carry small heaters anymore because they have so many pilot issues technology has made them "too safe."
He said he'd look at videos if I'd send them, I did, but haven't heard back, suspect I won't.
It's my hope someone might recognize my description and images of symptoms as something that makes sense. Could it be the tanks? The fuel itself? Something else?
  • 20241125_181818.mp4
    6.8 MB
  • 20241125_183203.mp4
    2.2 MB
Hmm. Haven’t done a whole lot of work on “ventless” units, but that pilot is ghosting. Usually, that is caused by a lack of combustion airflow. On the backside of the pilot tube, there is a small hole, maybe 3/32” diameter. That’s the Oxygen Depletion Sensor (ODS). If that becomes fully or partially blocked with dust, dirt, pet hair or anything else, it could cause this issue. If you locate that ODS, try clearing it out with a can of compressed air. Let us be know if that works.
Thanks for the reply (and glad to know that's what it called)!
I did do that as part of my troubleshooting in February and last month. I used canned air and stuck a thin brush through just for good measure.
