i have an older pepin and all of a sudden it started to feed continuously and causing the stove to over heat so much so the paint started to burn anyone out there with an answer cause i haven't a clue
j-takeman said:So you have no control over the auger speed? I am taking this as an older analog board with the dial for heat adjustment?
I am not sure I would run that stove if the auger just keeps turning and turning. Careful with this. Sounds like the board lost a triac or timer relay. Not sure on how St Croix controled the auger in there anolog boards.
djb473 said:I cleaned the stove and now the auger seems to be cycling but now i have a lazy flame going on
{ the lite cycles every 10.5 sec}
SmokeyTheBear said:Make certain your damper is set properly as krooser will tell you start at a pencil width.
