I really don't like how my whole house wood furnace blower cycles on and off constantly during the first hour or two of the burn cycle, and then not run at all during the last 3 or 4 hours of the burn cycle. I mean it does a pretty good job of heating the joint, but I think it could do better with a variable speed blower that had a target duct temp it was aiming toward. I have the adjustable pulley on the blower motor set to run at a minimum speed now to help with the cycling, I really can't go any slower or the blower wouldn't be able to keep up with the oil burner, on the rare occasion that it runs. I guess I should say that this is a Yukon Husky wood/oil combo unit. Anyways, my idea is to come up with a automatically variable speed blower arrangement (on the cheap) So it appears there are several ways as to how this is accomplished. I found this fan controller for greenhouses that may have possibility http://www.ebay.com/itm/121221129954?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT but I'm not sure it would handle my 1/3 HP motor start up load. (belt drive blower)
I could get a surplus DC motor, but how to control it exactly? A cheapy PLC with a thermocouple input running a DC controller of some sort? Where to access this stuff on the cheap? Old treadmill? Washer/dryers? Used CL furnace with variable speed blower? I thought I'd throw this out there, see what ideas some of you fellow tinkerer types have?
