First off I would like to say thank you for this great site. I have found it to be very useful lately in my quest for a new stove. I am just getting ready to install a new wood stove and thought I would ask everyones opinion in the way I should proceed.
I just bought a new house, 2400 square feet, 1400 upstairs 1000 downstairs in a finished daylight basement. The stairs are centrally located in the house. The house currently does not have a chimney, or fireplace of any kind. I am looking to install one and have a couple of quotes coming in around $2400. I am not sure how well the house is insulated, it was built in 1995 and has vaulted ceilings and 6, yes 6, sliding glass doors on the deck side of the house. 4 upstairs, 2 downstairs. They all face south. My electric bill for August and Sept was around $225 and I kept it warm during the day when we are at work. I am guessing not that well insulated especially with all the glass. I am thinking that I will put the stove in the basement against the south wall which is the central location, right between the two sliding glass doors, this was the recommendation of the man that came and quoted the install. The chimney will be outside and will be fairly tall. I am guessing at 25 feet plus. I have always owned steel stoves in the past. I have burned wood literally my entire life as a primary heat source and the last 13 years as my only heat source, so you can imagine that I am a freaking out not having one. I was not going to install one until next year but the prospect of no wood heat this winter has me scrambling to get it done. I have been looking at some of the cast iron stoves, specifically the Jotul's and the Quadra-fires as well as one by Avalon. I really like the look but am nervous about them vs steel. Reading on here has calmed that a little but I also have no experiance with the new stoves. I have seen some top loader Iron stoves that were really cool. My last stove for 14 years was a Orly knockoff. It heated us out, but our house was only 1000 sq feet. Any ideas on the size of stove I might need and whether I should stick to a steel stove or switch to a iron one. As I have said, thanks for all your help.
Kenny
Kenny
