It's time to replace my old pre-EPA wood furnace add-on as well as my normal home propane furnace.
Current setup is a terracotta lined masonry chimney, 7x13 rectangular flue, external on the house, approximately 25-30 feet tall attached to an olde Energy Mate in my basement that runs in parallel with my Amana 90 II furnace that just took a dump on me.
I'm a bit stuck here now -- Ideally I know I need to line my chimney with a 6" stainless liner. I've never had a creosote issue with my current chimney, and with snow and ice on the ground paired with a 12x12 pitch roof, Installing a chimney liner simply isn't going to happen until spring, so some of the super high efficiency wood furnaces are completely off the table because of that.
House is 1800 SQFT, basement, middle floor, upper level. Cold air intake installed in the basement to help my current unit burn cleaner as I simply didn't have enough combustible air in the basement.
So here's the scoop. I contacted 12 heating and cooling places, and NONE of them will install a new wood furnace for me except for one. He said he'd install it exactly to manufacturer's specifications which I'm completely cool with, but I'd be responsible for buying the unit and getting it in the basement.
The problem is, I have no way to determine what my draft is, and I want to make sure I'm getting the unit that best suits my chimney both now and after it's lined.
I've narrowed it down to the US Stove 1551E or Englander 28-4000.
The Englander requires no greater than .05 in water column, the 1551E is no greater than .06 in water column.
I understand the 1551E is likely going to be more efficient as it has a bunch of automatic dampers on it etc, whereas the 28-4000 is just an NC30 in a different shell. The 1551 appears to be a lot bigger (I think) and my concern is electronics tend to wear out eventually. Damper servos, etc make me a little nervous. I don't know anything about electronics, and just to heat my dang house.
Radiant heat doesn't matter at all to me since it's going to be in the basement -- my concern is simply what's the better choice for creosote build up to get me through the winter until I can line my chimney in the spring.
I don't have the wood to continue to run my Energy Mate alone all winter as I normally run about 65% wood/ 35% propane.
I imagine the larger WC is likely "better" or less stringent for a bigger chimney like mine, but maybe not, and I know there's a lot of science that goes into WC, but any direction would be great.
Thanks!
Thanks!
