Hi all,
I am new to this forum and excited to tap into the wisdom of its members.
I have a home in the Bronx that has a masonry cut out fireplace. I've befriended a tree guy who's given me lots of wood and I have been splitting and stacking wood in the back yard and hoping to keep this up, and put it to use to help heat my home.
For a while I was looking at inserts: the Regency 1150 and the Supreme Fusion 18 both should fit in the fireplace. These got pretty expensive as I'd need to get a new model. I started searching on craigslist and found some Vermont Castings stoves coming up. Disclosure: I'm very familiar with the Defiant. My father has one in his home and I've used it a lot. Also, I dabble in old woodworking machinery and am aware that the quality of things that were once made very well has dropped significantly.
I'm now trying to get a few questions answered:
1. One of the benefits of an insert is it seals the opening so you don't lose so much heat up the chimney. If I get a free-standing fireplace like a VC Intrepid, is there a way to seal between the 6-inch liner and the chimney (somewhere towards the bottom of the chimney) to serve the same purpose as an insert would in closing up those gaps?
2. I'm seeing VC Intrepid 2 come up in sales of used fireplaces. I've read some mixed reviews (but too many unhappy customers for my liking). If I educate myself more about maintenance and care, can I make it work with one of these? Is there another model that's a similar size that folks would recommend?
3. If I go with a free-standing stove, it would need to have a horizontal pipe section before it can go straight up the chimney. How long can these horizontal chimney pipe sections get before they hurt the draw/exhaust?
4. I'd like to have a clean/efficient burn, and I've read that newer fireplaces are becoming tougher to work with because of these features. I don't mind needing to replace a converter or wear piece every 4-5 years if necessary (I say this so casually now...). I don't mind leaving the door cracked a little to help with draw as I get the fire started. Are there other major drawbacks to using these secondary burn systems that I am unaware of? Is the headache not worth it?
Thanks again everyone,
Matt
Matt
![[Hearth.com] Help me find the right Wood Stove! [Hearth.com] Help me find the right Wood Stove!](https://www.hearth.com/talk/data/attachments/289/289056-7d310dd02ddc32fc96969e04e50f9186.jpg?hash=IDJDgEdJ7p)
![[Hearth.com] Help me find the right Wood Stove! [Hearth.com] Help me find the right Wood Stove!](https://www.hearth.com/talk/data/attachments/289/289057-376de03a36441c89101d8d6e3d49e325.jpg?hash=SPpAkgBjLx)
