Hey guys! It looks like I am finally going to go after a stove.....but I have a problem. I live in an old 1800sqft two story colonial that doesn't have a woodstove friendly floor plan. The only place a stove will fit is in the corner of our dining room. The dining room isnt that huge so we absolutely need a low corner clearance stove. I need help finding some!
Here are the constraints:
1. Corner clearance of 6" or less for an unprotected surface. We will be using double wall pipe.
2. Width of no more than 25"ish.
3. Depth no more than 22" but the smaller the better. The more corner clearance needed, the narrower the stove will have to be.
4. The closer to a 2.0cf firebox (or larger) the better.
5. Can't cost more than $1,500....we're on a budget
The Goal:
1. To have a stove that will be the main source of heat while we are home. When we are away the existing heat stays at 55.
2. To have as close to an overnight burn as possible. I don't need a roaring fire when I wake up, just enough coals to start a new fire.
I'm a woodstove newbie and could really use your help! Thanks!
The Goal:
