Since I'm such a tinker-er, my next thought is to attack my circulator pump setup.
Here is what I have:
My supply is 1.5" from the boiler. There is a Tee that has 2 ports: 1 1/4" and 3/4".
3/4": Indirect Hot Water. This has a dedicated circulator pump and Tees off BEFORE the heating zones to make a "priority loop" for DHW demand.
1 1/4": Has a TACO 007 circulator and feeds 5 heating zones through 5 zone valves.
My return is 1.5" into the boiler. The 3/4" DHW return feeds into the return first, then the 5 heating zones come in.
I am thinking one of the more modern circulators to feed the zones might make the system as a whole more efficient.
The question is: "which one?"
Grundfos Alpha:
ECM motor (supposedly much cheaper to run)
Delta P
~$160
I think this would adjust pump speed to maintain a consistent flow through the zones as the valves open/close based on pressure drop.
Taco Delta T:
Not ECM motor
Delta T control
~$160
I think this would adjust pump speed to maintain a consistent temperature drop from supply to return, adjusting speed as the zones open/close and the heating demand changes. One of my concerns is that I can't get an accurate "return" temp without influence from the DHW return. Would that be a problem? Will this pump cost more than the Alpha to run since it isn't ECM?
Taco Viridian:
ECM Motor
Delta P
Price: Unknown
Does swapping the circulator to a modern one sound like a good idea? If so, which one?
ac
Grundfos Alpha:
Delta P
~$160
Taco Delta T:
Not ECM motor
Delta T control
~$160
Taco Viridian:
ECM Motor
Delta P
Price: Unknown
ac
