Slightly improved picture. It looks like a portable camp cookstove.
As for safety I have no idea of the integrity of the stove, but the issue may be more with the flue. The color of that connector says overfire. No idea about the thimble, but it looks suspect too.
Mike - I think you might also want to review the clearance to combustibles for that setup. I am seeing a couple of potential problems that should be corrected before use.
It wouldn't hurt to get a set of professional eyes (chimney sweep) to inspect the stove and stack for integrity. BG and his eagle eyes caught the sure signs of an overfire on your connector pipe. That doesn't mean it is broke, just that you may want to take a good hard look at everything before you proceed.
I have every intention to replace all chimney components.
The stove itself is very solid and sturdy, no rust or decay of any kind.
Opinions of having only top-load function?
Maybe some smoke inside cabin, but no risk of embers/logs falling out onto floor when opening.
Others?
Anyone know from the pic what make/model?
top loaders don't smoke if the chimney is functioning properly. makes loading pretty easy, but start ups are a bit tougher if you have to load kindling/paper in from the top
pick isn't clear enough for an ID, and it may not be a well know maker/etc
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
