Just registered here, after a few years lurking and hunting answers. Thanks to all here for maintaining such an informative forum. I'm having a hard time finding answers to my current problems, so I'm posting my first post!
Photos are attached for clarity. The insert is a Stuv 16-78. Installation required cutting out the existing fireplace's damper and a hole big enough to fit the 7" diameter flue liner (still have several feet of that left over, if anyone is interested). The primary problem is we need to design a surround. We don't like the black sheet metal surrounds that come standard with most inserts/installers, in part because it would be fit over the brick and not flush with the brick. We want flush. We're not opposed to metal either (the stove came with a small spray can of paint that matches the stove - for touch-ups presumably), but I'm not a metal worker so.... One important piece of info: we can't find matching brick, though we have tried.
Here are my questions:
Thank you for any answers you might have!
![Help designing insert surround Help designing insert surround](https://www.hearth.com/talk/data/attachments/281/281211-cf8c9ee0a939ebfcdfa1565c61cb70b3.jpg)
![Help designing insert surround Help designing insert surround](https://www.hearth.com/talk/data/attachments/281/281212-0cb93ca1a9050a1db6aca470dfc5e614.jpg)
![Help designing insert surround Help designing insert surround](https://www.hearth.com/talk/data/attachments/281/281213-32d7b9f8a33de2984f69d459359c5778.jpg)
- If we were to tile over the space, is there a backer board that could handle that much heat so close to the stove? The temperature ratings I saw at the hardiebacker website seemed too low for this application (100 degrees Celsius).
- If backer board is available for this application, how should I attach it? There's nothing behind onto which to screw/nail it, so I assume I would have to install something. What could I install, and how would I attach it to the brick/iron?
- Is there a material available in the US that I could work like wood? I noticed that vermiculite is available in the UK, but I'm not sure about here.
- If backer board is an option, would I need to install extra support for the horizontal space above the stove, or is the backer board strong enough to hold up the tile (if the backer board is only attached at the sides)?
- If I was to have a metal surround made to fit the space (47" x 30"), what's a fair price?
- What specs should I be looking for in the primer and paint?
- Is there a rating I need to look for in tile that makes it suitable for this high heat application?
- Bonus question: We have some old end irons in the shape of owls, with yellow glass eyes. If I was to have a metal surround built, and the owls cut and welded onto the surround, is there a way for the heat from the stove to power LEDs behind the eyes, so they glow?
