Please Help ![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
I am building a wood splitter from scratch. Before I make a major mistake or waste money on the wrong parts, I would like to know in what order / sequence the following components that I already have, should be connected:
A 2.8 gallon hydraulic oil tank with an optional suction strainer, both are ½ N.P.T.
B 20 G.P.M. Return line filter with ¾ N.P.T.
C Haldex 2 stage, 16 G.P.M. Pump, (SpeeCo # HC390709).
D 2 way valve, 30 G.P.M., 2000 psi fixed relief, ½ N.P.T.F. Working ports.
E Red Lion welded cylinder, 2500 psi, 24” stroke, 4” bore, model #40WC24-200.
Also, what type / rating of hoses and fittings should be used?
Any help you can provide would be greatly appreciated.
Thank You, Mark
Thank You, Mark
