I just bought a new freestanding wood stove. I am now in the process of gathering information before building my hearth. One thing I'm struggling with is calculating R values. According to my manual and many others I've found online, I need a minimum R value of 1.19 to pass inspection and meet code. I have seen others here use durock or wonderboard which are readily available from Lowes & Depot. But I don't understand a couple of things.
I have found several sources on the web that list various materials and their R-values. For example, see:
https://www.hearth.com/articles/64_0_1_0_M1.html
Durock & Wonderboard have an R value of .52 PER INCH. This stuff is generally sold in 1/2" thick sheets. Since the minimum requirement is 1.19 and 1.19 divided by .52 = 2.29, that seems to me to indicate that I would need 2.29 inches of durock or wonderboard, or 5 half inch sheets piled up on top of each other (and since these are only sold in 3'x5' dimensions and my hearth is bigger than that, I could need to purchase 10 sheets). I have seen others here using just a two sheet thickness (one inch) which has me confused. Am I calculating this right? If not, can someone please explain it to me?
Thanks!!
p.s. Of course this is ONLY considering the durock layer. The tile I will put on top has some r value, but I also read you should not even count the tile towards your total because you never know for sure what its value actually is unless you can find some specific rated name brand, and then you have the issue of the grout.
p.p.s. I know micore 300 has much better R values, but I'm having trouble finding this material locally. Should I just make an extra effort to find that stuff?
Thanks!!
