- Sep 25, 2007
- 24
I have been heating my house with a wood stove for 10 years and I have decided to get a wood furnace. I am tired of the mess in the living room from the bark, sawdust, bugs and ashes. Also I am tired of one really hot rooms and the opposite corner of the house being cold. So here is my plan and questions. Any help suggestions would be greatly appreciated.
First off I am thinking of either a USSC 1557 or a Vogelzang Wood/Coal Model# 2500. Is one significantly better than the other. Any feature(s) on one which are better? Any other brand you might suggest in the $1000 range? The USSC is convenient because I can go pick it up at Tractor supply.
I want to install it in my attached garage. Just on the other side of the wall in the basement is the furnace so I can just run 2 ducts through the wall under the first floor of the house. I know it would be more efficient to put it in the basement, but then I have to haul wood through the house into the basement and still have the mess problem. There is no outside access to the basement and I would have to cart it down the stairs. It would be so easy to fill in the garage. Plus it would keep the garage warm. I would have to use 8" supply and return ducts. Any thoughts on this configuration?
When you connect the furnace to the existing furnace, the units are in parallel. I still have to use the propane furnace bacuse I travel quite a bit and have to keep the house warm when I am out of town.
When they are in parallel how do you prevent one from backfeeding air through the other (ie. When the propane furnace runs the air could flow through the wood furnace to the cold air return? and vice versa. Do you install butterfly valves or something?
Where can I find info on installing the chimney to code? I live near Columbus Ohio. one of the main things is where the chimney exits the roof of the garage, it will be next to the wall of the second story. I need to know clearance for that etc.. There is no room to run the chimney horizontal out the back of the stove and up the side of the house.
How does the thermostat work on those. Does the call for hot air from the thermostat in the house just turn on the forced combustion air blower? Are the internal blowers for warm air circulation controlled by an internal thermostat to cool the plenum to a fixed temp? basically how do I control it?
Thanks in advance.
Tim
Thanks in advance.
Tim
