is hedge good or bad to burn i know it don't cut worth a crap really hard. But does it burn good?
Get the in-ject-chain from baileys 35 cents a drive length it cuts slow but well worth it (that wood will be the best wood you every had!)Cutter said:I have read somewhere that an 8" fence post of OO will only lose one inch in size after being in the ground for 100 years. The stuff just does not rot. We have a pipeline that cuts through our land. It was installed in the late 1950s. Along the edges of the easement there are still piles of hedge that is still very sound. Only a little bit of lichens growing on them. I have considered cutting some of it up to burn but it is so darn hard that ie eats up chains like Cheetos. So I only cut it when it is green.
Brad
you save that wood for jan. feb.jdscj8 said:So when i burn it i should mix bigger rounds in with my walnut and oak to keep it from over firing. we are putting in a new Blazeking king parlor model in a few weeks so its going to be a learning experince in its self. i'm not to sure how to run these cat stoves yet and would hate to over fire it right from the start.
