More importantly, how big is the hop yard, and what varieties???View attachment 234636 View attachment 234635 Well, here it is: not sure how much it will be used for firewood, but I'm sure it will come in handy in its own way. Loll 400B off-road forklift. 17,000 lbs. GVW, 4,000 lb. lift capacity, maximum height of 34 feet. We're putting up a hop yard and need some vertical access--enter the Loll (nicknamed "Spankey" after the Little Rascal). Next up is to build the man cage and take her up for a ride. It has standard bobcat hydraulic connectors on the mast for fork twist/cant--not sure if it will have the GPM for a splitter or grapple. Power comes from a 225 CID slant-6 (older than I am, believe you me). It's just good, old-fashioned fun to drive this thing--crab steering, 4 wheel drive, LOUD! The kids are in heaven (and so is their Dad).
The ultimate top down chimney cleaning tool.View attachment 234636 View attachment 234635 Well, here it is: not sure how much it will be used for firewood, but I'm sure it will come in handy in its own way. Loll 400B off-road forklift. 17,000 lbs. GVW, 4,000 lb. lift capacity, maximum height of 34 feet. We're putting up a hop yard and need some vertical access--enter the Loll (nicknamed "Spankey" after the Little Rascal). Next up is to build the man cage and take her up for a ride. It has standard bobcat hydraulic connectors on the mast for fork twist/cant--not sure if it will have the GPM for a splitter or grapple. Power comes from a 225 CID slant-6 (older than I am, believe you me). It's just good, old-fashioned fun to drive this thing--crab steering, 4 wheel drive, LOUD! The kids are in heaven (and so is their Dad).
I don't know what it is or how/where I would use it, BUT, I want one.
you might want to look into purchasing a manlift, they aren't that expensive...
https://www.amazon.com/dp/B079RZ3S62/?tag=hearthamazon-20
Cool machine! Definitely check your hoses for drips, etc, and keep a rope ladder close by for when the guy up there gets stuck!
technically one of the rules of using a manlift is that it is only up and down movement, no forward or backward movement of the vehicleI would epoxy my boots to the floor in case a of a pothole.
technically one of the rules of using a manlift is that it is only up and down movement, no forward or backward movement of the vehicle![]()
Never heard of that rule before. I been driving manlifts and scissor lifts for over 40 years. If it has wheels on it it will be driven with someone in it and a small bump turns it into a rocket launcher.
doesn't apply to scissor lifts, but it does to a manlift on a forklift.
1926.453(b)(2)(viii)
An aerial lift truck shall not be moved when the boom is elevated in a working position with men in the basket, except for equipment which is specifically designed for this type of operation in accordance with the provisions of paragraphs (a)(1) and (2) of this section.
1926.453(b)(2)(ix)
Articulating boom and extensible boom platforms, primarily designed as personnel carriers, shall have both platform (upper) and lower controls. Upper controls shall be in or beside the platform within easy reach of the operator. Lower controls shall provide for overriding the upper controls. Controls shall be plainly marked as to their function. Lower level controls shall not be operated unless permission has been obtained from the employee in the lift, except in case of emergency.
1926.453(b)(2)(xii)
Before moving an aerial lift for travel, the boom(s) shall be inspected to see that it is properly cradled and outriggers are in stowed position except as provided in paragraph (b)(2)(viii) of this section.
That being said, I am always at least holding on when moving![]()
