@bholler @webby3650 @begreen and anyone else with information…
Do any of you have any experience with Heatshield or similar products? What’s your experience and opinions on it as to what it supposed to do?
I read where it’s supposed to fill in cracks in clay liners (I believe there was two products I read about to be used together in a clay liner), has a super high temperature rating, and supposed to allow a masonry chimney to pass clearance to combustibles with zero clearance I believe is what I read.
I realize it’s probably just as easy to rip out the clay and install an insulated liner. I’m wanting to know how the product actually stands up to its claims and also, in your opinion, if it performs as well as advertised, and in comparison to an insulated liner.
Give an example of when you’d recommend this, and/or if you’d ever recommend it.
I’m just wanting to know more about it. If it lives up to its hype, then I wonder how much advantage one would gain applying it directly to a new clay liner, say 6” round tongue-n-groove clay liners, just for the added temperature rating and clearance benefits, if any?
I really don’t see how this product can insulate well enough to change clearance on a masonry chimney, let alone perform like a 1” insulated liner or stainless Class A chimney.
Does anyone have any other knowledge of pre-cast chimney blocks/liners, all-in-one’s, super-refractory pre-cast chimney kits?
Messick Stove in PA was selling a pre-cast chimney and liner-in-one product a few years back, but I no longer see it listed on their website and I forget the products name.
EDIT:
I believe the product sold by Messick was called Isokern…yeah that’s it…
www.topstak.co.uk
I can’t see that Isokern pumice product holding up to heat over the long term as well as clay because from what I’ve seen of pumice bricks in stoves like Quadrafire they don’t seem to last too long.
EDIT:
![www.topstak.co.uk](/talk/proxy.php?image=https%3A%2F%2Fwww.topstak.co.uk%2Fapp%2Fuploads%2F2020%2F08%2FFlue-Block-318x324-1.jpg&hash=7f4babe5f9d76357ce5c23ccafe27240&return_error=1)
Isokern Access Flue Block - Pair
For DM Block Chimneys. Suitable for use in negative pressure (Dry Chimney) applications. CE Designation (T450 N1 D 3 G(00)
![www.topstak.co.uk](/talk/proxy.php?image=https%3A%2F%2Fwww.topstak.co.uk%2Fapp%2Fthemes%2Fv1%2Fimages%2Ffavicomatic%2Ffavicon-196x196.png&hash=2cc8952eda182cd4817d8af1ac3c7c29&return_error=1)
