Hey all - I have an electronic igniter that I think is shot (model # in subj). Symptoms, when turned on (via wall switch), I hear the familiar 'beep' which is normally followed by the igniter sparking and lighting the pilot, then main gas turns on. Now however, after the beep I hear nothing - as in there isn't the usual igniter sparking sound.
Troubleshooting so far - have performed a 'reset' - no change. Gas is on and unit has power. Am I right in suspecting the ignition control module?
If so, I see that the OEM replacement is expensive ($193 amazon) and the Dexen is much cheaper, but would it be a reasonable replacement?
Many thanks in advance,
