I have a G200s Heatmaster wood boiler that has a 'phantom' leak...
I went away for the weekend and stacked the boiler with wood (something I have done numerous times over the last 4 years) to keep it going as long as possible before my electric furnace (Back-up) comes into action.
When I returned 3 days later the Heatmaster had emptied itself out completely.. yeap there was a mega puddle on the ground and it had completely emptied itself. As I opened the the ash clean-out at the bottom of the boiler remaining water rushed out... and the gauge showed empty!
I decided to fill the boiler up again to see if I could identify where the leak was. I filled it up to full and looking into the rear of the ash box I could not see any trickle..dribble..or any water anywhere!? Its now 3 weeks and the gauge is still 'FULL' and no sign of any leak ANYWHERE... I have not lit it again.... WTF is going on?? All I can think of is that when it's running hot something is expanding and opening up a crack or seam. Any suggestions or has anyone experienced the same?
But that would not be a good idea! As you say, the only solution, will be to restart it and get it up to temperature as I suspect the leak occurs when everything expands and the affected area will start leaking again... however I will still be unable to see where its leaking from other than when it emerges through the ash clear-out section. The boiler has been in 5 years and Heatmaster have said they would not honour their 10 year warranty because I did not send in water samples to them for 2 seasons... rather difficult to do when we were snow-birding on both occasions and the boiler sat idle for the periods. So I have a bit of a 'situation' going on with them .. especially when they say they do not manufacture this unit anymore OR the smaller one! Incidentally when I decided to instal a wood boiler I calculated that a 100,000 BTU was sufficient for my needs BUT their agent (Untrained) insisted on the 200,000 BTU and that I should 'go big or go home' . I think he was talking about his commission! Anyway their rep said he is 'hunting around' to locate a boiler for me but I will be facing a $10K invoice + freight!!
I've also heard that Brian isn't very generous when it comes to warranty claims either. I also heard first hand from one of his dealers that he also doesn't like to pay dealers to fix boilers that aren't wired up correctly from the factory.
