Hello All,
I recently bought my family's old homestead and converted what used to be an old woodshop to a home office.
Overview of the room:
The room is pretty comfortable when it is ~35-40* outside temp. When it is less than this - it get's pretty cold, when it exceeds this exterior temp, it's pretty dang hot in here. I live in Western Massachusetts where winter time fluctuations are regularly ranging from 0* to 40* from day-to-day.
I had a Heat Reclaimer on the stove - but after researching more and learning that it had to continuously operate (regardless of heat in the room) - I discarded it.
I'm wondering if there's something I can do to circulate heat more aggressively during cold days that I can "turn off" in afternoons or days where I just need a little bit of radiant heat.
I use the office during business hours - so I usually let the fire go out overnight and restart in the morning. On a cold day, it takes some time to heat up in the AM.
Any suggestions/Help is appreciated. Thanks in advance!
- About 200 sq ft.
- Three walls are exposed to outside other wall is to adjoining unheated room.
- Walls are comprised of barnboard exterior, framing, then tongue and groove boards on interior
- ceiling is uninsulated - but is comprised of 1 layer of barn board, 3/4" plywood, and two layers of asphalt shingles on roof
- Concrete slab for floor
- Air tight for the most part - there are some pretty drafty spots but it's mostly air tight
- I have a Quadra Fire woodstove - unsure of make/model as the serial number plate was removed before I got it
- Pictures attached - interested if anyone knows which model this is
