Thank you for your help in this forum. I have searched the forum and don't see my problem addressed yet. If so, please direct me to the answer already listed.
I have a Heatilator Model ND4236, Serial GA1005589, Mfg. Date 2403 (mid June, 2003?) natural gas fireplace, which was installed in 2003. It has a standing pilot light, which ignites with a piezoelectric (press the red button) starter. The pilot light lights okay. However, it has been harder and harder to get the flame to burn when I turn on the wall switch.
I can do some diagnostics as shown in this YouTube video, “Diagnostic Testing For Gas Pressure and Gas Millivolt Valves.”
I have a gas furnace and gas water heater; both work fine. The furnace was serviced earlier this week so I doubt that I have a gas pressure problem. I have a RadioShack multi-meter and can check the thermopile. Terminals TH/TP and TP read .672. The video indicates 325 millivolt minimum, readings are generally 400 to 700 millivolts. So thermopile seems okay at .672.
I have clearance problems for the thermocouple testing and I don't have a replacement thermocouple if this is an issue. There is a metal plate attached to the bottom of the fire box with four wing nuts, This plate has the gas control valve, the pilot light, and the starter attached. The gas supply flex pipe appears to have enough flex to allow the detachment of the metal plate to get this assembly out for service on an installed fireplace. Is that how it is done?
The pilot light assembly has three connections. They are in order: a copper color, a silver (aluminum) color and a white fabric covered (one blue and one black dot painted on it) connections. I believe that the silver one is the pilot gas supply. It appears that of the other two, one determines if the pilot is lit to allow the pilot lit supply to stay on, which apparently is working because the pilot stays on. And one determines if the pilot is lit to allow the flame to light. Apparently, this sensor is not working.
I understand that there is a third sensor to determine if the chimney gas is too hot that is located at the top of the firebox, which also turns off the gas supply to the flame. This one could also be defective.
If the connection that determines that the flame is okay to light (the thermocouple?) is likely to be defective, then I will get one and get committed to replacing it. A Heatilator thermocouple appears on ebay for about $30 with shipping and shows as copper color. A thermopile is about $45. A whole Heatilator Direct Vent Fireplace Gas Pilot Assembly is about $80.
I am stuck at this point. What do you suggest?
