Well, it has been a while since I had been here. About three years ago the state knocked down my old house for an overpass. I got paid for it and some of the cash we used to buy a replace home. The replacement house was built in 1991 and the where the fireplace is to go was not installed.
So, this year we decided to put a new Heatilator Constitution zero clearance unit as it fit in the space where it was to go. At the old house, I had been using an Olympic Wood Fireplace Insert by Avalon. That thing was a monster and kept out 1200 sq ft home toasty just fine.
The new unit has been installed and the job has been done and the shop here I got it said it is OK to use it now but we will need to wait for the stone as the installer is swamped with the Hurricane Harvey as about 200,000 homes were underwater
Now with the few fires I have had since I got it, I am happy. As the season goes, I will find if it will heat the whole house or not – it is a two story about 1600 sq ft home. I did get the forced air for one of the second story rooms.
But the question today I have is how is can you know how hot is the unit getting? With the Olympic I had a stick on magnetic thermometer dial and you knew how hot it got as the steel was just there. It seems with the Heatilator, it seems there is a space between the face and the firebox. When THREE splits of oak, I use the infrared gun, the glass goes to about 600 – 650 and the frame in the middle of the gun says it is about 500 – 550. The face (just the middle of the two doors) says it goes about 320 – 350 where the dial is. With those three spits last for over two – three hours and the dial keeps it at 350 or longer. There is room for more wood, but I do not want to over fire it.
BTY, I have about 10 cords of wood or more I cut myself in 2013 and 2014 before the move and it has been cut, spilt, stacked and covered so the wood is OK and has less than 20% moisture and I am in OK that department.
I really do not want to over fire it, so what is the right temperate to run it? Or better yet, where to point the gun to know what the ‘right’ temperate is? Do I check the glass, the frame where the two doors meet, at the face of the top of the doors, or any other spot to get a true reading?
Thanks, Robert
![Heatilator Constitution Zero Clearance Heatilator Constitution Zero Clearance](https://www.hearth.com/talk/data/attachments/201/201218-5a042686dab87b71408295882404d52c.jpg)
Thanks, Robert
