Heatilator BC36R inner walls...
burningntexas
3
Dallas TX
Hello all,
I am new here and honestly, never thought I would find a forum like this for fireplaces but I am glad I did. My wife and I bought a new home 4 years ago and it came with a 36" Heatilator BC36R woodburning fireplace. It's pretty small and not very good quality but it works for what we need so we use it. Well, the inner walls are made of a fibrous terra cotta like material. The side, bottom and back walls are all cracked and degraded and I was told that is dangerous.
I need to replace them but I don't know what these things are called. They are the panels that line the inside of the fireplace. I had a chimney sweep tell me to get a firebacker and I am cool with that but what about the bottom and side walls? I don't know where to get these and the internet has resulted in no results except Heatilators website that doesn't even list this model. Help! Is there anything I can replace these with?
btw.. a friend told me I could pull the existing panels out, and use them to make molds to cast my own cement versions of these panels. He said I could use common quickrete to cast the replacement panels. Is this true? I really don't want to burn my house down.
btw.. if nobody knows the answer to this can you atleast point me in the right direction to find out? Please, I love my fireplace but cannot burn it this winter if I don't get this resolved. Help?!?!
Ok, I found that perlite concrete is what gas fireplace logs are made of. Surely I can use this to make my walls out of? I found this on Perlite's site.
Perlite lightweight concrete is used in many different applications. These include lightweight tile mortar, garden sculpture, decorative brick, gas-fireplace logs and floor fills.
There was a post on here about a place where you could get refractory materials from to replace broken pieces. I did a search and can't seem to find it, maybe one of the others here can find it for you.
Good luck!
BTW- I'm no expert by any means but I wouldn't put quickrete in that hot of an application. I have been told that concrete can literally blow apart from extreme temperature.
