heat output on a 30 year old baseboard
Rugar
134
East central KS
Don't know what make of baseboard but what was an average output of an old baseboard. I'm thinking my old boards don't give off enough heat. My circulators are running nonstop with 178 deg water and max temp in house is 70 on cold days.
thanks
Vacuum the dust and cat hair out of the fins. Make sure there isn't a couch with a long dust ruffle on it sitting in front of most of it blocking the flow of air over it. Turn the high limit on your wood boiler up to 190 degrees... at least 185... heat transfer from baseboard radiation occurs better at 180 degrees... you'll move more air with the higher temperatures.
Mine works better at 185 than at lower temperatures. The oil burner doesn't run nearly as much because there is a bigger "pad" between the two.
thanks
